Julian Klepacki
Viewing 15 posts - 1 through 15 (of 139 total)
  • in reply to: reconstructive surgery #12983
    seal
    c post 1
    c post 2
    c post 3
    c post 4
    c post 5
    c post 6
    c post 7
    c post 8
    BT 1
    BT 2
    BT 3
    BT 4
    good job paul.
    that interior looks fantastic
    interior 1
    interior 2
    interior 3
    in reply to: interiors n’stuff #12795
    Hi Paul,
    Thanks for the links. I looked at C.Classics parts shop and didn’t see it, don’t think they stock it?
    Carpet, yeah. I htink it’s just a balls up on the supplier/maker. It was a bloke recommended from here many years ago. I’ve been somewhat dissapointed in the whole lot to be honest. The actual finishing in a lot of areas, particular seating/door cards isn’t quite up to scrtatch for a pro in my book. It looks a little ameteur.
    1. Apron covers.
    3. Upper sill covers
    5. Sill carpets and so on.
    Oh, your car is looking stunning. It’s looks fantastic out of M&M paint shop.
    in reply to: EFI throttle linkage – reconnection #12781
    keep us posted on your endeavours.
    in reply to: interiors n’stuff #12780
    interior now covered with sound deadening bitumen or whatever it is & sound isolator closed cell foam.
    interior 1
    interior 2
    carpet 1
    trim 1
    in reply to: Hello from Wiltshire #12779
