good job paul.
that interior looks fantastic
Hi Paul,
Thanks for the links. I looked at C.Classics parts shop and didn’t see it, don’t think they stock it?Carpet, yeah. I htink it’s just a balls up on the supplier/maker. It was a bloke recommended from here many years ago. I’ve been somewhat dissapointed in the whole lot to be honest. The actual finishing in a lot of areas, particular seating/door cards isn’t quite up to scrtatch for a pro in my book. It looks a little ameteur.
1. Apron covers.
3. Upper sill covers
5. Sill carpets and so on.Oh, your car is looking stunning. It’s looks fantastic out of M&M paint shop.
keep us posted on your endeavours.interior now covered with sound deadening bitumen or whatever it is & sound isolator closed cell foam.
I might investigate some bits & bobs, but mostly gather parts in prep. -
