Julian Klepacki
Viewing 15 posts - 1 through 15 (of 144 total)
  • in reply to: reconstructive surgery #13095
    c post
    b post
    inner sill
    paint prep
    spacer 1
    spacer 2
    sill covered
    retainer
    nylon Y
    in reply to: Hello from Wiltshire #13044
    Wow, that 66 looks great.
    It’s only money.
    Gotcha!
    seal
    c post 1
    c post 2
    c post 3
    c post 4
    c post 5
    c post 6
    c post 7
    c post 8
    BT 1
    BT 2
    BT 3
    BT 4
    good job paul.
    that interior looks fantastic
    interior 1
    interior 2
    interior 3
