Julian Klepacki
Viewing 15 posts - 1 through 15 (of 135 total)
  • in reply to: Front/Rear Loudspeaker fader control #12958
    BT 1
    BT 2
    BT 3
    BT 4
    good job paul.
    that interior looks fantastic
    interior 1
    interior 2
    interior 3
    in reply to: interiors n’stuff #12795
    Hi Paul,
    Thanks for the links. I looked at C.Classics parts shop and didn’t see it, don’t think they stock it?
    Carpet, yeah. I htink it’s just a balls up on the supplier/maker. It was a bloke recommended from here many years ago. I’ve been somewhat dissapointed in the whole lot to be honest. The actual finishing in a lot of areas, particular seating/door cards isn’t quite up to scrtatch for a pro in my book. It looks a little ameteur.
    1. Apron covers.
    3. Upper sill covers
    5. Sill carpets and so on.
    Oh, your car is looking stunning. It’s looks fantastic out of M&M paint shop.
    in reply to: EFI throttle linkage – reconnection #12781
    keep us posted on your endeavours.
    in reply to: interiors n’stuff #12780
    interior now covered with sound deadening bitumen or whatever it is & sound isolator closed cell foam.
    interior 1
    interior 2
    carpet 1
    trim 1
    in reply to: Hello from Wiltshire #12779
    in reply to: Hello from Wiltshire #12776
    in reply to: EFI throttle linkage – reconnection #11740
    throttle
    I might investigate some bits & bobs, but mostly gather parts in prep.
    in reply to: EFI throttle linkage – reconnection #11738
    Regarding part #1 it can’t really be fitted incorrectly. it stays on the shaft #2 and flat-peice with slots isn’t flat, but angled, following the contour of base #6 it bolts to.
    Anyway, it’s now sorted :).
    I bought a cheap chinkwainese borescope to allow investigation without having to get too far under the car. I identified that the cable was still attached, the main worry and no bracketry appeared to be causing fouling. But needed a better view than what the scope gave.
    I started working towards getting the car high enough, safely to get right under. Then thinking about it, as i have been constantly. I wasn’t sure, but the bow, #10, which on my car is a tube and not flat pressing. Was hanging down a little low? Though not improbably, seemed incorrect?
    i concluded that when i replaced the assembly into the locator #4, the position of the pedal was too ‘vertical’. This would have placed the eye for the cable higher, slackening the cable. Still unsure about the lack of movement?
    So before i started getting axle-stands out, raising suspensions etc, crawling around underneath. I thought, lets just try this: I free’d up the assembly by disconnecting #1. Pulling the assembly from the locator #4, allowing me to rotate the assembly, positioning the pedal a little further towards the floor.
    Once relocated back into #4 with the new assembly position, all is good.
    I think the lack of movement was caused by the pedal itself fouling on the base #6. Becasue it was initially placed too vertical, it allowed it to slide towards the bulhead just enough for metal to overlap and cause the problem. Should have taken a photo, simpler to see than explain. Car is put to bed now for the winter all covered up.
    in reply to: EFI throttle linkage – reconnection #11727
    just to add, i didn’t remove the pedal. after removing the two screws that hold #1 to the base plate #6. i could tip the pedal end up just enough to massage #6 out. It was afterwards when i was cleaning/painting the floor the assembly got moved about too much and messed it all up.
