Julian Klepacki
Viewing 15 posts - 1 through 15 (of 134 total)
  • in reply to: Sh*t Just Got Real….. #12957
    good job paul.
    that interior looks fantastic
    interior 1
    interior 2
    interior 3
    in reply to: interiors n’stuff #12795
    Hi Paul,
    Thanks for the links. I looked at C.Classics parts shop and didn’t see it, don’t think they stock it?
    Carpet, yeah. I htink it’s just a balls up on the supplier/maker. It was a bloke recommended from here many years ago. I’ve been somewhat dissapointed in the whole lot to be honest. The actual finishing in a lot of areas, particular seating/door cards isn’t quite up to scrtatch for a pro in my book. It looks a little ameteur.
    1. Apron covers.
    3. Upper sill covers
    5. Sill carpets and so on.
    Oh, your car is looking stunning. It’s looks fantastic out of M&M paint shop.
    in reply to: EFI throttle linkage – reconnection #12781
    keep us posted on your endeavours.
    in reply to: interiors n’stuff #12780
    interior now covered with sound deadening bitumen or whatever it is & sound isolator closed cell foam.
    interior 1
    interior 2
    carpet 1
    trim 1
    in reply to: Hello from Wiltshire #12779
    in reply to: Hello from Wiltshire #12776
    in reply to: EFI throttle linkage – reconnection #11740
    throttle
    I might investigate some bits & bobs, but mostly gather parts in prep.
    in reply to: EFI throttle linkage – reconnection #11738
    Regarding part #1 it can’t really be fitted incorrectly. it stays on the shaft #2 and flat-peice with slots isn’t flat, but angled, following the contour of base #6 it bolts to.
    Anyway, it’s now sorted :).
    I bought a cheap chinkwainese borescope to allow investigation without having to get too far under the car. I identified that the cable was still attached, the main worry and no bracketry appeared to be causing fouling. But needed a better view than what the scope gave.
    I started working towards getting the car high enough, safely to get right under. Then thinking about it, as i have been constantly. I wasn’t sure, but the bow, #10, which on my car is a tube and not flat pressing. Was hanging down a little low? Though not improbably, seemed incorrect?
    i concluded that when i replaced the assembly into the locator #4, the position of the pedal was too ‘vertical’. This would have placed the eye for the cable higher, slackening the cable. Still unsure about the lack of movement?
    So before i started getting axle-stands out, raising suspensions etc, crawling around underneath. I thought, lets just try this: I free’d up the assembly by disconnecting #1. Pulling the assembly from the locator #4, allowing me to rotate the assembly, positioning the pedal a little further towards the floor.
    Once relocated back into #4 with the new assembly position, all is good.
    I think the lack of movement was caused by the pedal itself fouling on the base #6. Becasue it was initially placed too vertical, it allowed it to slide towards the bulhead just enough for metal to overlap and cause the problem. Should have taken a photo, simpler to see than explain. Car is put to bed now for the winter all covered up.
    in reply to: EFI throttle linkage – reconnection #11727
    just to add, i didn’t remove the pedal. after removing the two screws that hold #1 to the base plate #6. i could tip the pedal end up just enough to massage #6 out. It was afterwards when i was cleaning/painting the floor the assembly got moved about too much and messed it all up.
    in reply to: EFI throttle linkage – reconnection #11726
    How did i not see 2.142/3 dwg? It’s only a couple of slides on from my incorrectly identified dwg?
    Anyway, mmmm. I think i have two issues. firstly the eye on the cable is likely detached. especially is there is nohting on the end to prevent doing; c-clip etc?
    when i looked at my photo of that end, it looks like it just ends at the bush, not seeing the arm continue due to the dark/contrast of the image. I couldn’t feel it as i was at the end of my reach with the car sitting on the deck.
    secondly, i wonder if on the pedal side, that flat-end of the straight bar #2 that locates in #10 has come adrift? But you say you can see it, located and secure? Somehting is definitely preventing the pedal moving forward.
    Before disturbing it all to process the floor it was all 100% functional, A-O.K.
    I hope i can sort it out easy enough; get it on stands, get under and fiddle it correct? But i envisage it’s going to be a complete pain in the arse. I hope i don’t have to do anything obscene like remove the effin’ engine/box to do it? There seems to be no room to work/access whatsoever at the sides between the box & bulkhead where all the crap is?
