no bother, offers there.
very neat with the brass tube.
Doesn’t matter it’s not seen, you know it’s there.
We all do the same, go to unnecessary lengths for stuff that ultimately doesn’t matter.Definitely inspect mine come the time. It won’t be until next spring/summer now.
It’s presently all exposed, so before all the covers go back on for sure.Good job on the clean up & recal.
That pressure tester looks a brilliant piece of kit.
How bad is the broken case, do you have all the parts or at least most for reference?
I’m thinking it’s an ideal thing & easy by the looks of it to 3D-print a new one?
Do you have access to a printer?
If not and you’d like, i can print some on my next period at work?
how did you deal with the rivet after, presumably drilling off the rolled edge?To add to Pauls info on understanding the wiring, you might be lucky and it is a bad connection.
but, those cibies is that somehting you can get new or are they nos items?i think your approach to the car is spot on.
engine bay looks fantastic.you’re right, there a lots of ameteur folks out there doing incredible work on all sorts vehicular.
I think, when you try and do stuff yourself to the best outcome given facility and ability. Often not reaching the result you have in your mind, accepting them, living with them etc. Based on ones own efforts, you very much appreciate high-end workmanship & attention to detail of others.Reading the back story to your car, I drew numerous parallels with my own story: Car stored hours away from home, impossible to get anyhting done. Life getting in the way, times when you simply forgot you had the car. Frustrations with the situation, thoughts of giving up and it goes on.
Spectacular Paul.
Truely inspirational.
Outstanding.Yeah, i can do that.
If it comes to nothing or gets ruined in the process, no big deal.I have found some seals that look very promising too.
Dimensionally compatible & possible.not much more to report on this other than i pressed the impeller shaft out.
It came out real easy. I use floor standing 30T press, but it took no force at all to push out.I’ll get some 12mm ground bar to replicate it, save messing about sleeving. filling those pits.
I did think, you could reverse the shaft and place the nice smooth end into the impeller. Those small bearings wouldn’t care about the pitted shaft.While i was at it, i took 0.3mm off the cast-seat to get rid of the rings/grooves.
Then decide do i put it all back together or try and implement an alternative seal?Made a stainless spacer for the bearings. Original, though fits on the shaft nice and runs smooth.
yeah.
I wonder what the configuration is of water pumps on other cars, earlier models from back in the day to more modern stuff. My recollection is that water pumps on the whole weren’t a common failure? Never had a water pump fail/changed on any of the cars, bangers & otherwise i’ve had in my motoring life?Yes, I’ve come across those shaft-savers. Can’t recall the correct name.
I still think i’d have a go at removing the shaft from impeller before messing about with one of those?photo of the seal from the impeller side. You can see the rubber face that seals against the central-boss of the impeller. The spring within the cupped-body that applies tension to the sealing faces, both front & rear graphite when the pulley is pressed on. How far you press it on dictates that tension. There’s also an internal rubber face, about 10mm in length/width that seals around the shaft too. In fact that rubber part is like a rubber cylinder/boss/slug ~18mm OD, 12mm ID & 10mm thickness. Pressed into the brass housing.
i wonder how a zerk-fitting and pack it with grease would perform?As mentioned before, no need to grind those rivets off. Just press the shaft straight out in a one’r. A bit of heat on the pulley would likely make things easier. It was on a big press, didn’t notice the gauge before it started to move. Few tonnes maybe?
more out of interest than necessity.order of parts on the shaft.
rear-face of pulley
pump body
yes, it is a factory pump.
Possibly replace rivets with cap-screws?I found some descriptions on aussie-frogs of folks modifying them for other mechanical seals.
So I am still intrigued of the possibility to repair/recon a pump with lasting results.I’ll load some photos of the parts, be a reference if nothing else.
I pressed out the impeller/shaft. Shame i ground the heads off the rivets on the pulley, thinking it was necessary to remove the pulley first. I didn’t have to. Didn’t have an appropriate puller for the pulley. Pressed the shaft out directly, came out easy enough with pulley in situ.Pulled the outer larger bearing out, then pressed out the inner smaller bearing along with the cast-seal-seat.
I’ll do some further research. Satisfied a curiosity for now.Really? why?
