Julian Klepacki
Viewing 15 posts - 1 through 15 (of 146 total)
  • in reply to: reconstructive surgery #13118
    Just touching back on that rubber strip. Yeah, it’s frustrating, but we are all used to badly fitting third-party components. It’s the same on everyhting. I thought when they initially make the tooling/moulding for this stuff, no idea if it is extruded or injection moulded or whatever. Anyway, when the first one is made and found to be incorrect. Adjust whatever so it is correct? Apart from that the strip looks good.
    in reply to: reconstructive surgery #13099
    While we’re in that area how does the ‘ear’ as i’ll call it on the sill carpet sit? That piece of carpet i see coming out fronm under the front corner of the seat. Is this that ear, or a piece that covers the tank-bulkhead?
    Thanks for the link to your blog. I gives some good info. efi routing is complicated by the fact at least one line needs to do a 180 to come back on itself to go into the fuel pump. Whichever way you face the pump. Also the ‘Y’ piece introduces further complexity. It is not helped with the pump being mounted quite close to the centre gussets. It all leads to a potential monkey’s knuckle of pipework and fittings, as i have with rubber hose install. Needs thought to minise complexity, bends, future access etc. Like to see a factory install, see if it had ‘U’ bent nylon or some other affair? if only to improve on it?
    in reply to: reconstructive surgery #13095
    c post
    b post
    inner sill
    paint prep
    spacer 1
    spacer 2
    sill covered
    retainer
    nylon Y
    in reply to: Hello from Wiltshire #13044
    Wow, that 66 looks great.
    It’s only money.
    Gotcha!
    seal
    c post 1
    c post 2
    c post 3
    c post 4
    c post 5
    c post 6
    c post 7
    c post 8
    BT 1
    BT 2
    BT 3
    BT 4
    good job paul.
    that interior looks fantastic
    interior 1
    interior 2
    interior 3
