Julian Klepacki
Viewing 15 posts - 1 through 15 (of 167 total)
  • in reply to: Nearly There! #13474
    Good job on the clean up & recal.
    That pressure tester looks a brilliant piece of kit.
    How bad is the broken case, do you have all the parts or at least most for reference?
    I’m thinking it’s an ideal thing & easy by the looks of it to 3D-print a new one?
    Do you have access to a printer?
    If not and you’d like, i can print some on my next period at work?
    how did you deal with the rivet after, presumably drilling off the rolled edge?
    in reply to: SANOR Headlamp Relay #13456
    To add to Pauls info on understanding the wiring, you might be lucky and it is a bad connection.
    in reply to: Nearly There! #13388
    but, those cibies is that somehting you can get new or are they nos items?
    in reply to: Nearly There! #13374
    i think your approach to the car is spot on.
    engine bay looks fantastic.
    you’re right, there a lots of ameteur folks out there doing incredible work on all sorts vehicular.
    I think, when you try and do stuff yourself to the best outcome given facility and ability. Often not reaching the result you have in your mind, accepting them, living with them etc. Based on ones own efforts, you very much appreciate high-end workmanship & attention to detail of others.
    Reading the back story to your car, I drew numerous parallels with my own story: Car stored hours away from home, impossible to get anyhting done. Life getting in the way, times when you simply forgot you had the car. Frustrations with the situation, thoughts of giving up and it goes on.
    in reply to: Nearly There! #13370
    Spectacular Paul.
    Truely inspirational.
    Outstanding.
    in reply to: Water pump #13329
    Yeah, i can do that.
    parts
    yeah.
    seal
    seal1
    housing
    housing1
    impeller
    order of parts on the shaft.
    pump1
    pump2
    pump3
    pump4
    rear-face of pulley
    pump6
    pump7
    pump body
    pump5
    yes, it is a factory pump.
    in reply to: Water pump #13205
    I pressed out the impeller/shaft. Shame i ground the heads off the rivets on the pulley, thinking it was necessary to remove the pulley first. I didn’t have to. Didn’t have an appropriate puller for the pulley. Pressed the shaft out directly, came out easy enough with pulley in situ.
    Pulled the outer larger bearing out, then pressed out the inner smaller bearing along with the cast-seal-seat.
    I’ll do some further research. Satisfied a curiosity for now.
    in reply to: Water pump #13196
    Really? why?
    in reply to: New Toy Alert #13167
    very good.
    Even if it doesn’t get used often. When it’s needed it’s priceless.
    Yeah, your diy tool looked to have worked out great too.
    Probably the route i’ll take come the time.
