Julian Klepacki
Viewing 15 posts - 1 through 15 (of 147 total)
  • in reply to: reconstructive surgery #13123
    I’ve had another play with the carpets.
    So just to be clear, there should be vinyl glued to the tank-enclosure front panel that rolls over onto the enclosure lid, missing from my photo below. Assists as a hinge & covers the top-edge.
    Then the vinyl on those ears is stuck to the front of the same panel, inevitably on top of the vinyl that is stuck to help hinge the lid? Or is that vinyl ‘hinge’ piece short, so it doesn’t go full width, sitting between the ear-vinyl?
    It seems a bit messy and would be better to not have that vinyl on the ears and simply a piece across the whole width of top-edge. Let those ears just lay flat, held down by the seat? I’m thinking, because those ears cut across the corners, if you lifted the cover vertical, hinged at the front, it would pull those ears up, possibly out of the metal-trim, uplifting glue. Without them being held down, they’d just lift up?
    sill carpet
    The carpet I have for the front of the tank box is unfinished. I think I’ll need to stich a binding onto it to tidy up that top edge? Possibly the sides too. There is a gap between the sill-carpet vertical edge and that rectangular piece. An edging will help close up that gap. But I don’t have any foam/padding or anything on the metal that would also bring the carpet forward a little and help close up that gap too.
    I think I’ll have to fit the centre seat-box section early on. Mine doesn’t have a finished edge, like oem looks to have. It relies on the finished edge of the sill carpet to hide the raw edge. So fitting sill carpets after this makes it easier to deal with the edge? Also see what i mean about the untidy holes for the seat-base bolts. Hacked with a stanley as opposed to using an appropriate circular punch. It could also do with being stiched again with the joining seam layed flat. As it is, it isn’t and makes the join sit high. I might remake the whole piece and repurpose the material elsewhere.
    centre carpet
    Finally, who does this!
    pocket
    Finishing the edging on the top edge, all exposed and not even rolled over. Which would not be good either, as it would be quite bulbous? Obviously it should be finished at the bottom, where it would be either hidden at best by the floor carpet or at the very least much less notcieable.
    Amateur.
    in reply to: reconstructive surgery #13118
    Just touching back on that rubber strip. Yeah, it’s frustrating, but we are all used to badly fitting third-party components. It’s the same on everyhting. I thought when they initially make the tooling/moulding for this stuff, no idea if it is extruded or injection moulded or whatever. Anyway, when the first one is made and found to be incorrect. Adjust whatever so it is correct? Apart from that the strip looks good.
    in reply to: reconstructive surgery #13099
    While we’re in that area how does the ‘ear’ as i’ll call it on the sill carpet sit? That piece of carpet i see coming out fronm under the front corner of the seat. Is this that ear, or a piece that covers the tank-bulkhead?
    Thanks for the link to your blog. I gives some good info. efi routing is complicated by the fact at least one line needs to do a 180 to come back on itself to go into the fuel pump. Whichever way you face the pump. Also the ‘Y’ piece introduces further complexity. It is not helped with the pump being mounted quite close to the centre gussets. It all leads to a potential monkey’s knuckle of pipework and fittings, as i have with rubber hose install. Needs thought to minise complexity, bends, future access etc. Like to see a factory install, see if it had ‘U’ bent nylon or some other affair? if only to improve on it?
    in reply to: reconstructive surgery #13095
    c post
    b post
    inner sill
    paint prep
    spacer 1
    spacer 2
    sill covered
    retainer
    nylon Y
    in reply to: Hello from Wiltshire #13044
    Wow, that 66 looks great.
    It’s only money.
    Gotcha!
    seal
    c post 1
    c post 2
    c post 3
    c post 4
    c post 5
    c post 6
    c post 7
    c post 8
    BT 1
    BT 2
    BT 3
    BT 4
    good job paul.
    that interior looks fantastic
