Julian Klepacki
Viewing 15 posts - 1 through 15 (of 163 total)
  • in reply to: Nearly There! #13370
    Spectacular Paul.
    Truely inspirational.
    Outstanding.
    in reply to: Water pump #13329
    Yeah, i can do that.
    parts
    yeah.
    seal
    seal1
    housing
    housing1
    impeller
    order of parts on the shaft.
    pump1
    pump2
    pump3
    pump4
    rear-face of pulley
    pump6
    pump7
    pump body
    pump5
    yes, it is a factory pump.
    in reply to: Water pump #13205
    I pressed out the impeller/shaft. Shame i ground the heads off the rivets on the pulley, thinking it was necessary to remove the pulley first. I didn’t have to. Didn’t have an appropriate puller for the pulley. Pressed the shaft out directly, came out easy enough with pulley in situ.
    Pulled the outer larger bearing out, then pressed out the inner smaller bearing along with the cast-seal-seat.
    I’ll do some further research. Satisfied a curiosity for now.
    in reply to: Water pump #13196
    Really? why?
    in reply to: New Toy Alert #13167
    very good.
    Even if it doesn’t get used often. When it’s needed it’s priceless.
    Yeah, your diy tool looked to have worked out great too.
    Probably the route i’ll take come the time.
    in reply to: reconstructive surgery #13158
    good thinking, i looked at coverdales site, it might be included but not seen on their carpet set picture.
    in reply to: reconstructive surgery #13156
    in reply to: reconstructive surgery #13154
    yes, I will experiment with a carpet ‘insert’.
    I think optimally, the whole carpet section wants replacing. Then punch out accurately-placed holes. Even over those front screws and then use some form of plastic cap/plug to finish it. That way, those bars could be removed, slid out without having to pull-up glued carpet. Or simply not glue the carpet down? Strategic velcro strips?
    Regarding that foot-pad. My carpet has a ribbed rubber pad stitched in. Coverdales, based on their website image appear to do the same? So it’s far from the look of an oem installation.
    It looks like the sort of matting you get for workbenches; anti-static, electricl isolation etc. That sort of thing? A quick google throws up various options.
    On another note, any ideas what this section of carpet might be for?
    It came with my set, but I can’t figure out what it might be for?
    carpet
    It looks to form an oblong boxy type thing.
    in reply to: reconstructive surgery #13130
    Your carpets look factastic. How did you repair the plastic foot-pad. Previous photos show it somewhat broken up? I believe at 6’4″ you too are beyond the comfortable/practical range of the front seats?
    Here’s what I got now.
    It’s still tempory, i need a seat in to turn the car around to then work on the NS sill area.
    Below is what I’m proposing to implement.
    Relocation-rails remounted, inset into the sound-proofing, they now sit pretty much flush.
    They utilise M7 countersunk screws to bolt flush.
    The front bolts are temp normal hex-heads, as i failed to order enough. Brainfart.
    rails 1
    Carpet with slots punched for the mounting bars to exit at rear.
    Also seat-base mounting holes punched for front bolts. They can be seen just behind the seam between carpet & hardura. Original hacked holes remain.
    rails 2
    I don’t consider additional strain, if any on the seat-base fixings. Those 8mm bars are giving as much support as the floor. Possibly more? The fronts of the bars aren’t stressed and cannot attempt to ‘lift’ because of the rear mount. The only place of concern was the section of bar overhanging. That is quite small and would take a lot of force to bend, a lot. Factor in the actual seat base bolted to it. Adding even more support with the angle-section steel-sides and the little gussettes by the fixing holes.
    Seat base extends a little beyond the rear mounting bolt before it kicks-up a little. The bars support the base all the way. Nothing is extended, applying more leverage. Simply mounted in a different place.
    rails 3
    With the seat mounted and in the furthest back position. You can see that the forward mounting holes are quite visible and need to be addressed. Either covered up appropriately or a complete new carpet correctly, neatly punched. The seta back-back is now kinda inline with the b-post.
    rails 4
