Wow, that 66 looks great.
I know what I would do in the same situation wanting a good car to fettle and get my tinkering-fix. But fudamentally drive & enjoy.Little update, dropped in to see the Banbury South African car. Looks very nice and got around the lanes beautifully. Everything looked pretty straight and in good order and I might be tempted……
It’s only money.Gotcha!
good job paul.
that interior looks fantastic
