Julian Klepacki
Viewing 15 posts - 1 through 15 (of 169 total)
  • in reply to: reconstructive surgery #13487
    Over the good days through september i’ve managed to repair the C-post & sill on the NS of the car.
    The C-post initially looked like it wouldn’t need much. But as usual, once you started diggin’ in, it was as bad as the OS.
    I had to put several small patches into the sill-apron lower edge. It would have been easier to simply get a repair panel and weld the entire lower edge in. But I didn’t have one and couldn’t wait for the days taken to get one.
    Since doing the OS, I’d purchased one of Machinemart spot-drill cutters. The ones that are like a mini hole-saw. I found it much better than a drill-bit type. As i found these often, suddenly, if not very careful cut through the entire metalwork. With the hole-saw type, it effectively leaves the ‘spot’, but thats is nicely dealt with removing with flap-wheel, rotary-file etc leaving a good base for the new plug-weld.
    Most of the rot cut out. I ended up cutting the rear-side more, cutting it higher.
    c-post1
    Small repair patch to inner panel + the lttle tab that secures it underneath.
    cpost 2
    Starting to take shape. Had to re-shape the seal-holder, as typically it was badly formed.
    cpost3
    Metal-work done. Still ned to tidy it up with filler etc, but that has to wait until next summer now.
    Can see the door-seal-channel is quite bad here too.
    I replaced all the very lower parts of the door-seal-channel. But the others were only 3-4 inches in length.
    cpost4
    Rotten channel removed, until it gets good enough to leave it.
    seal trim
    New seal-channel tacked in, it goes up to about half way, but thankfully all a straight piece.
    seal trim 2
    Fwd section of sill. Apart from that very lower edge the sills are good. There was some underseal/coating, which has obviously saved them. I scraped off what i could, cleaned it all up, added hydrate-80 to surface rust patches and applied couple of coats of Jotum 90. ALl the hydrau-pipes are good. I cleaned them with a 3M pad and coated with hydrate 90 in effort to preserve them going forward.
    fwd sill
    Aft sill section. When they get boxed up i’ll spray some dinitrol or something in there, just for an additional layer of protection. Though it’s all fairly well coated now.
    aft sill
    Oh, I also replaced the little ‘C’ channel that holds the bottom seal on the B-post. Luckily the post itself was pretty good. Couple of holes i welded in small round-patches about the size of a halfpence.
    Next summer I can prep & apply paint and add the covers. Then, finally I can see about the bloody carpets.
    in reply to: Nearly There! #13477
    no bother, offers there.
    very neat with the brass tube.
    Doesn’t matter it’s not seen, you know it’s there.
    We all do the same, go to unnecessary lengths for stuff that ultimately doesn’t matter.
    Definitely inspect mine come the time. It won’t be until next spring/summer now.
    It’s presently all exposed, so before all the covers go back on for sure.
    in reply to: Nearly There! #13474
    Good job on the clean up & recal.
    That pressure tester looks a brilliant piece of kit.
    How bad is the broken case, do you have all the parts or at least most for reference?
    I’m thinking it’s an ideal thing & easy by the looks of it to 3D-print a new one?
    Do you have access to a printer?
    If not and you’d like, i can print some on my next period at work?
    how did you deal with the rivet after, presumably drilling off the rolled edge?
    in reply to: SANOR Headlamp Relay #13456
    To add to Pauls info on understanding the wiring, you might be lucky and it is a bad connection.
    in reply to: Nearly There! #13388
    but, those cibies is that somehting you can get new or are they nos items?
    in reply to: Nearly There! #13374
    i think your approach to the car is spot on.
    engine bay looks fantastic.
    you’re right, there a lots of ameteur folks out there doing incredible work on all sorts vehicular.
    I think, when you try and do stuff yourself to the best outcome given facility and ability. Often not reaching the result you have in your mind, accepting them, living with them etc. Based on ones own efforts, you very much appreciate high-end workmanship & attention to detail of others.
    Reading the back story to your car, I drew numerous parallels with my own story: Car stored hours away from home, impossible to get anyhting done. Life getting in the way, times when you simply forgot you had the car. Frustrations with the situation, thoughts of giving up and it goes on.
    in reply to: Nearly There! #13370
    Spectacular Paul.
    Truely inspirational.
    Outstanding.
    in reply to: Water pump #13329
    Yeah, i can do that.
    parts
    yeah.
    seal
    seal1
    housing
    housing1
    impeller
    order of parts on the shaft.
    pump1
    pump2
    pump3
    pump4
    rear-face of pulley
    pump6
    pump7
    pump body
    pump5
    yes, it is a factory pump.
    in reply to: Water pump #13205
    I pressed out the impeller/shaft. Shame i ground the heads off the rivets on the pulley, thinking it was necessary to remove the pulley first. I didn’t have to. Didn’t have an appropriate puller for the pulley. Pressed the shaft out directly, came out easy enough with pulley in situ.
    Pulled the outer larger bearing out, then pressed out the inner smaller bearing along with the cast-seal-seat.
    I’ll do some further research. Satisfied a curiosity for now.
