Your carpets look factastic. How did you repair the plastic foot-pad. Previous photos show it somewhat broken up? I believe at 6’4″ you too are beyond the comfortable/practical range of the front seats?
Here’s what I got now.
It’s still tempory, i need a seat in to turn the car around to then work on the NS sill area.
Below is what I’m proposing to implement.Relocation-rails remounted, inset into the sound-proofing, they now sit pretty much flush.
They utilise M7 countersunk screws to bolt flush.
The front bolts are temp normal hex-heads, as i failed to order enough. Brainfart.
Carpet with slots punched for the mounting bars to exit at rear.
Also seat-base mounting holes punched for front bolts. They can be seen just behind the seam between carpet & hardura. Original hacked holes remain.
I don’t consider additional strain, if any on the seat-base fixings. Those 8mm bars are giving as much support as the floor. Possibly more? The fronts of the bars aren’t stressed and cannot attempt to ‘lift’ because of the rear mount. The only place of concern was the section of bar overhanging. That is quite small and would take a lot of force to bend, a lot. Factor in the actual seat base bolted to it. Adding even more support with the angle-section steel-sides and the little gussettes by the fixing holes.
Seat base extends a little beyond the rear mounting bolt before it kicks-up a little. The bars support the base all the way. Nothing is extended, applying more leverage. Simply mounted in a different place.
With the seat mounted and in the furthest back position. You can see that the forward mounting holes are quite visible and need to be addressed. Either covered up appropriately or a complete new carpet correctly, neatly punched. The seta back-back is now kinda inline with the b-post.
Granted, not often needed to lift the lid, but when you do; sender, fuel-connections, whatever. It could prove frustrating? I’ll experiment with those ears, It’s in my nature to always think about access, future maintenance etc. Hence the potential overthinking about the ears.
I’ll have to try, but I suspect you have to fit the lid from a fairly vertical position to insert the roll-hinge and fold it down to secure? So I’m htinking the tank and all that really wants to be in before the carpet assembly starts?
My oblong front panel carpet is also overly long. I fitted it square at that edge to save on bulk in that area during trials. But your point about it wrapping around onto the sill, like mine can, will solve the gap issue. I can trim back the foam underlay on the inner-sill, so the carpet won’t cause an offset for what it’s worth.
My issues with the seat-frame fixing holes are more about professional quality of work. But, my particular case is somewhat complex. I am tall, a smidge over 2m and not as slim as i used to be. I find the seat position too far forward when furthest back. I have devised some mountings made out of flat bar to allow the seat frame to be mounted further back, ~100/125mm.
above is during a trial fitting on top of the carpet. But mounted like this, the front sections are visible when seat is right back. I considered making/printing some plastic covers to hide the front sections.
But i’m now thinking to fit them ‘under’ the carpet. Cutting out the underlayers where they sit will bring them level with underlay and provide a somewhat firmer mounting, not being bolted through layers of crushed carpet & foam etc.
I would need to make exit holes in the hardura for the bar coming out the rear & punch new holes for the frame, but that will leave the forward original hole exposed. Hence the thoughts of making a new section. Either that or attempt to cover/fill the existing hole. Maybe a plastic disc/plug of sorts might not look so bad and even allow access to the mounting-screw without removing the carpet? The rear hole will be covered by the seat-frame. Might be onto something there?
Possibly oem made the centre carpet glued on top because of the bulk. I think if you wanted a fairly flat seam, you’d have to stich it flat and even hammer it too flatten it more? I know you won’t really see it, but it’s there.
Yes, the bulkhead carpet stiched inside out is proper isn’t it. Coverdal look to do it the same as oem, as with other sections too. Stiching like this also ‘bows’ out the top opening nicely. Instead of being somewhat flat like mine? I guess soemhting in there will shape it out anyway.
I know the carpets will look great when finally fitted with a complete interior. Specific flaws detracted by the overall look of inside and mostly not even seen. You can somewhat over-focus looking specifically, in deatil at a particular point. Anyway, don’t worry Coverdale did not make the carpet. Brian Cates did ~17 years.
A quick google now responds with good, OK & don’t use. Mostly from many years ago. No idea if he is still trading? My experience is ‘OK’. Overall is good, but finishing is poor I.M.O.
I will play with tank-lid & the centre-carpet, my extension-runners and think about options. I’m liking my sudden idea about plug/discs to cover holes. Will simplify work alot.
I’ve had another play with the carpets.
So just to be clear, there should be vinyl glued to the tank-enclosure front panel that rolls over onto the enclosure lid, missing from my photo below. Assists as a hinge & covers the top-edge.
Then the vinyl on those ears is stuck to the front of the same panel, inevitably on top of the vinyl that is stuck to help hinge the lid? Or is that vinyl ‘hinge’ piece short, so it doesn’t go full width, sitting between the ear-vinyl?
It seems a bit messy and would be better to not have that vinyl on the ears and simply a piece across the whole width of top-edge. Let those ears just lay flat, held down by the seat? I’m thinking, because those ears cut across the corners, if you lifted the cover vertical, hinged at the front, it would pull those ears up, possibly out of the metal-trim, uplifting glue. Without them being held down, they’d just lift up?
The carpet I have for the front of the tank box is unfinished. I think I’ll need to stich a binding onto it to tidy up that top edge? Possibly the sides too. There is a gap between the sill-carpet vertical edge and that rectangular piece. An edging will help close up that gap. But I don’t have any foam/padding or anything on the metal that would also bring the carpet forward a little and help close up that gap too.
I think I’ll have to fit the centre seat-box section early on. Mine doesn’t have a finished edge, like oem looks to have. It relies on the finished edge of the sill carpet to hide the raw edge. So fitting sill carpets after this makes it easier to deal with the edge? Also see what i mean about the untidy holes for the seat-base bolts. Hacked with a stanley as opposed to using an appropriate circular punch. It could also do with being stiched again with the joining seam layed flat. As it is, it isn’t and makes the join sit high. I might remake the whole piece and repurpose the material elsewhere.
Finally, who does this!
Finishing the edging on the top edge, all exposed and not even rolled over. Which would not be good either, as it would be quite bulbous? Obviously it should be finished at the bottom, where it would be either hidden at best by the floor carpet or at the very least much less notcieable.
Amateur.Just touching back on that rubber strip. Yeah, it’s frustrating, but we are all used to badly fitting third-party components. It’s the same on everyhting. I thought when they initially make the tooling/moulding for this stuff, no idea if it is extruded or injection moulded or whatever. Anyway, when the first one is made and found to be incorrect. Adjust whatever so it is correct? Apart from that the strip looks good.
While we’re in that area how does the ‘ear’ as i’ll call it on the sill carpet sit? That piece of carpet i see coming out fronm under the front corner of the seat. Is this that ear, or a piece that covers the tank-bulkhead?Thanks for the link to your blog. I gives some good info. efi routing is complicated by the fact at least one line needs to do a 180 to come back on itself to go into the fuel pump. Whichever way you face the pump. Also the ‘Y’ piece introduces further complexity. It is not helped with the pump being mounted quite close to the centre gussets. It all leads to a potential monkey’s knuckle of pipework and fittings, as i have with rubber hose install. Needs thought to minise complexity, bends, future access etc. Like to see a factory install, see if it had ‘U’ bent nylon or some other affair? if only to improve on it?
Wow, that 66 looks great.
I know what I would do in the same situation wanting a good car to fettle and get my tinkering-fix. But fudamentally drive & enjoy.Little update, dropped in to see the Banbury South African car. Looks very nice and got around the lanes beautifully. Everything looked pretty straight and in good order and I might be tempted……
It’s only money.Gotcha!
