Viewing 15 posts - 1 through 15 (of 809 total)
  • in reply to: Nearly There! #13945
    The adaptor is M10 male, screws into the block with a bit of PTFE tape. Switch, 18NPT, screws into adaptor with a bit more PTFE tape.
    I did the switch into the adaptor first, adaptor in vice, tightened switch with water pump pliers. Then whole lot into block.
    in reply to: Nearly There! #13943
    https://www.ebay.co.uk/itm/301122237169
    plus
    https://www.ebay.co.uk/itm/372564854550
    20psi switch plus adaptor.
    Original switches operate at about 3psi, far too late.
    in reply to: Nearly There! #13940
    I fitted a 20psi modern sender from Demon Tweaks and used the necessary adaptor to make it fit.
    in reply to: Hello from Wiltshire #13915
    Definitely spray some Dinitrol, Bilt Hamber or your favourite into the doors. While you’re at it, paint some onto the door bottoms.
    in reply to: Hello from Wiltshire #13910
    in reply to: Hello from Wiltshire #13909
    I changed it to free
    Woolies don’t list them.
    They nearly always break when you try to remove them, so don’t!
    in reply to: Hello from Wiltshire #13908
    Dash dial.
    Plus the speedo’s are carp.
    I think it is black.
