Viewing 15 posts - 1 through 15 (of 793 total)
  • in reply to: New petrol tank preservative #13427
    Fresh oil sounds OK.
    Or.
    Similarly at the fan.
    It is heavy.
    Did you get it sorted?
    1
    1
    Duplicate post.
    Crusty shaft repair.
    Speedi Sleeves by SKF
    Der Franzose part numbers
    30384
    And
    30270
    Have fun.
    I had welded the centre.
    My mistake?
