For the handbrake, no.
For lights left on, yes!Did the eagle eyed notice a parking brake warning light marked P in white?
Here’s the wheel
Wrapped steering wheels.
Start the engine, needle drops back to bottom then slowly rises with engine temperature.My saloon uses a converted fuel gauge. Needle only moves with rising engine temperature.
Replacing curvy rusted steel is not my forte. Luckily, filler is.Looking in my crystal ball I can forsee many trips to AFT Fluorotec in Welwyn Garden City. Burning off the paint and filler in their oven. Home to repair. Back again to hot zinc spray the seams. Back home for epoxy primer.
But can only do one panel at a time to stop flash rusting.The top coats will be cellulose. Pretty user friendly and doesn’t need a separate air supply to the hood.
Quite a palaver as the axle stands were two feet high. Blocks of wood, three trolley jacks and a lot of huffing and puffing.It was exciting when the last few inches were at 32 feet per second per second. At least the bump stops worked.
It’s also best to plan the route of the hose, it may save you three attempts to get it right.At this rate I may have to start on bodywork…
I haven’t cut the end taper yet.I’m now attempting to wrap the steering wheel. My word, a very frustrating and long winded job.
I’ll persevere but I’m tempted to get the foam wheel (original) exchanged for a refurbished one.I blew through my banjo bolt just to make sure, 20W50 oil isn’t the greatest taste.
I gave the clips on the LHM pipe an extra tweak, leak has gone for now. I have ordered 8mm and 10mm pipes and two joiners, then I’ll have a spare.Today I undid the banjo oil feed to the head and span the engine. After a few revs, oil pumped out the fitting. I re-annealed the copper washer thing and tightened it.
I restarted the engine and the oil pressure is better.
I’ve also ordered a remote oil pressure kit so I can check the pressure.The Citroen oil pressure switch is set to about 2 or 3 psi, or basically wet with oil.
If you can get underneath, access is reasonable, preferably with a ring spanner. Once it’s out, a blast with brake cleaner up the spout of the switch may help.
A 10 psi switch is on order, I already have the adaptor for the block (M10 to 1/8 bsp).
And this is meant to be fun!
