Viewing 15 posts - 1 through 15 (of 770 total)
  • in reply to: Hello from Wiltshire #13045
    Like this
    in reply to: EFI throttle linkage – reconnection #12759
    I asked Jamie. No need to remove the engine. Maybe give him a call. After 11am is best.
