Viewing 15 posts - 1 through 15 (of 764 total)
  • in reply to: Sh*t Just Got Real….. #12955
    Like this
    in reply to: EFI throttle linkage – reconnection #12759
    I asked Jamie. No need to remove the engine. Maybe give him a call. After 11am is best.
    in reply to: Workshop Manuals and Parts Books #12758
    in reply to: Manual to bvh #12750
    Imgbb is messing around and I can’t find how to delete posts.
    Last try.
    in reply to: Manual to bvh #12749
    Imgbb are messing about.
    in reply to: Manual to bvh #12748
    in reply to: Manual to bvh #12747
    If you want the starter motor to be ignition switch controlled, then delete the wire from terminal 85. Instead take a wire from pin 2 of the ignition switch to 85.
    That way, the starter motor can only operate if the ignition is switched on.
    in reply to: Manual to bvh #12746
    If you haven’t got a Daisy wheel on the positive battery post, this is how I would do it.
    I use a 70amp relay because terminals 30 and 87 are larger and can accommodate larger wire. It is overkill.
    Using a relay reduces the amount of current going through the piddly switch on the gear lever. It stops the contacts burning out.
    I crimp and solder the connections using leaded solder. Never had a problem in 40 years.
