I drive mine like I stole it. You’ll find me in lane 3.
Don’t over think it.
Unless you do a double blind test with the same car over the same route, you won’t know.
Are your front and rear arms in perfect condition?
Tyres and tyre pressures?
If you want to stop the rolling, you could fit the Xantia Activa set up with an extra three (or four?) spheres.I certainly wouldn’t pass the ‘Princess and the pea’ test.
I changed mine for comfort spheres, I didn’t notice any difference at all.I used an MGB internal deflector. I too tried duct tape on the closed roof, made no difference.
I’ve toyed with the idea of a flush mounted, bonded front screen. It would be possible if the screen rubber was fitted all round the screen but I can’t think of an elegant solution at the bulkhead.It is just a noisy car.
I had to use a lump of oak and a BFH to remove the liners.Then the fun starts.
Timing chain and tensioner.
Cam polished.
Tappets refaced.
New starter motor (Wosp).
New handbrake pads.
Change gearbox oil.
Check all three parts of clutch.It’s a simple engine. Nothing too tricky. Pay attention to fitting dizzy drive. It can’t be changed once box and block are back together.
I used British Standard wiring colours. Much easier to fault find as you can easily see what the wire connects to and from.If you don’t want a multi-connector at the top of the wing, there are numbers which clip on the cable available to help identification.
Not a lot of people know that.Condensation.
Both of mine do it.
This is why mild steel exhausts rot out.I just wrote a long reply, tried to post and the poxy forum said members only.
Logged back in, post gone.
Can’t be bothered…..Filler is like HP and tomato sauce, the profit is what’s left on the plate.
More DA action tomorrow.
Once I’ve hung the doors and wings I can use filler to get it right (ish).If my doors had been good but just dented, I’m sure I could have corrected the dents.
And buy another big tub of filler!A foregone conclusion, myself and panel beating don’t get on.
Hooray for filler! Lots of it.Here are a few things I can recommend if revitalising your loom. All from Vehicle Wiring Products.
Peter
