I didn’t need it when I had a puncture in Loire, just a new ‘chambre d’air’.When I had a Marcos, the steering column went through the fan belt. The trick was to fit two. One on the pulleys, one tied up out of the way.
Maybe cable-tie a spare to the new one. Similar to a spare clutch cable in the non Pallas roof channel.I have a brace. DSuper5, from Olivier. I have rebuilt the engine etc.
I bought mine 10 years ago. Did nothing for 18 months and then a year off when I was ill. Otherwise a few hours a day, every day.Bodywork is the most tedious, long winded, pain in the backside.
Can you spray a car? If you can’t, sit down before you get the quote.I would buy the best DSuper5 you can find.
Then drive it. No need to mollycoddle it. -
