Viewing 15 posts - 1 through 15 (of 799 total)
  • in reply to: Hello from Wiltshire #13885
    I think it is black.
    One wire goes to earth.
    Take the relay out.
    Terminal 86 goes to earth
    Terminal 30 is live feed
    Terminal 87 goes to headlamp.
    Fresh oil sounds OK.
    Or.
    Similarly at the fan.
    It is heavy.
    Did you get it sorted?
    1
    1
    Duplicate post.
    Crusty shaft repair.
    Speedi Sleeves by SKF
