Viewing 15 posts - 1 through 15 (of 746 total)
  • in reply to: Ds pallas 1972 Comfort ride spheres #12704
    Don’t over think it.
    Unless you do a double blind test with the same car over the same route, you won’t know.
    Are your front and rear arms in perfect condition?
    Tyres and tyre pressures?
    If you want to stop the rolling, you could fit the Xantia Activa set up with an extra three (or four?) spheres.
    in reply to: Ds pallas 1972 Comfort ride spheres #12694
    I certainly wouldn’t pass the ‘Princess and the pea’ test.
    I changed mine for comfort spheres, I didn’t notice any difference at all.
    in reply to: external wind deflector #12297
    I used an MGB internal deflector. I too tried duct tape on the closed roof, made no difference.
    I’ve toyed with the idea of a flush mounted, bonded front screen. It would be possible if the screen rubber was fitted all round the screen but I can’t think of an elegant solution at the bulkhead.
    It is just a noisy car.
    in reply to: Piston & Liner Replacement Shortcut ? #12244
    I had to use a lump of oak and a BFH to remove the liners.
    Then the fun starts.
    Timing chain and tensioner.
    Cam polished.
    Tappets refaced.
    New starter motor (Wosp).
    New handbrake pads.
    Change gearbox oil.
    Check all three parts of clutch.
    It’s a simple engine. Nothing too tricky. Pay attention to fitting dizzy drive. It can’t be changed once box and block are back together.
    in reply to: Loom wire gauges #12241
    I used British Standard wiring colours. Much easier to fault find as you can easily see what the wire connects to and from.
    If you don’t want a multi-connector at the top of the wing, there are numbers which clip on the cable available to help identification.
    Thinwall Single Core Cable
    Japanese Terminals
    in reply to: Exhaust dumping excessive water #12220
    Not a lot of people know that.
    in reply to: Exhaust dumping excessive water #12218
    Condensation.
    Both of mine do it.
    This is why mild steel exhausts rot out.
    in reply to: Crusty #12184
    I just wrote a long reply, tried to post and the poxy forum said members only.
    Logged back in, post gone.
    Can’t be bothered…..
    in reply to: Crusty #12181
    Filler is like HP and tomato sauce, the profit is what’s left on the plate.
    in reply to: Crusty #12177
    in reply to: Crusty #12176
    More DA action tomorrow.
    in reply to: Crusty #12171
    Once I’ve hung the doors and wings I can use filler to get it right (ish).
    If my doors had been good but just dented, I’m sure I could have corrected the dents.
    And buy another big tub of filler!
    in reply to: Crusty #12167
    A foregone conclusion, myself and panel beating don’t get on.
    Hooray for filler! Lots of it.
    in reply to: Main wiring loom from Battery to Key #12161
    Here are a few things I can recommend if revitalising your loom. All from Vehicle Wiring Products.
    https://www.vehiclewiringproducts.co.uk/c-46-battery-fittings-isolators/c-91-clamps-clips/p-279-battery-stud-nut-clamp
    https://www.vehiclewiringproducts.co.uk/c-48-cables/c-93-pre-made-battery-leads/p-579-battery-starter-cable
    https://www.vehiclewiringproducts.co.uk/c-52-fuse-boxes-fuses/c-122-blade-fuse-holders/p-662-surface-mount-side-entry-blade-fuse-box
    https://www.vehiclewiringproducts.co.uk/c-219-relays-flasher-units/p-647-12v-70-amp-high-current-relay
    Peter
    in reply to: Main wiring loom from Battery to Key #12159
    Peter here again.
    Have you an alternator with an external regulator in a box on the side of the battery or an internal regulator?
    There is something about BVH and the ignition warning light if you opt for internal regulation.
    Citroen did odd things with the wiring. The cable from the battery has two other wires spliced to it within the loom tape. Maybe they changed something and opted for three separate cables.
    Paul will chime in soon with his experience. Paul also has a BVH. Mine are both BVM.
