I changed it to free
Dash dial.
I think it is black.
One wire goes to earth.
Terminal 86 goes to earth
Terminal 30 is live feed
Fresh oil sounds OK.
Similarly at the fan.
It is heavy.
I’d be inclined to leave it alone and use the time to save some money, then get it done properly. -
