Viewing 15 posts - 1 through 15 (of 565 total)
  • in reply to: New thottle cable #10889
    How about the offering from Der Franzose?
    I’ve never seen one so am in the dark.
    in reply to: 170 miles to go #10888
    Unfortunately the saga was still not over. With the engine running,it was almost impossible to turn left, even with the wheels off the ground.
    With suggestions from Paul I re-measured the steering arm to pinion pad again. I had messed up.
    With the rack repositioned, normal service was resumed.
    All this palaver caused by using the wrong pulley nut. A new Nyloc nut and Loctite should do the trick.
    in reply to: 170 miles to go #10886
    I think a bead or two of weld stops the chatter. The broken one had beads of weld, the rivets were tight, just not the nut holding it on.
    I’m OK for pulleys thanks. Dead engines and gearboxes are a magnet for my shins.
    in reply to: 170 miles to go #10882
    That was not a job I wish to repeat too soon. 12 hours over four days.
    I did take the opportunity to change the radiator fan switch to one which switches on at a higher temperature. I also added a drain tap to the aluminium radiator.
    Once you’ve accepted what work has to be done to achieve the required outcome, you just have to get on with it. There was nothing tricky, just long winded.
    I finished with one m9 nut extra because I found it stuck to the undertray. Plus a load of m4 and m5 nuts and washers. Only an optimist would drop one nut or washer and get one new one from the spares case. I always lose one, bring back five to replace it.
    in reply to: 170 miles to go #10861
    It may have been the loss of the spring washer I had used. These days spring washers are carp. Another factor may be the air-con compressor adding an extra jolt.
    The end of the camshaft was the same diameter along the threaded length. The nylon part definitely comes into play.
    I shall put the dead pulley in the lathe and cut off the rivet heads to see how it comes apart.
    in reply to: 170 miles to go #10859
    in reply to: 170 miles to go #10856
    Most of the gubbins are back in place. I need to machine a couple of M9 nuts as the originals fell into the black hole, never to be seen again.
    in reply to: 170 miles to go #10854
    When I rebuilt this engine I used a split locking washer under the pulley nut. I can see it had fallen apart and disappeared allowing the pulley to wobble.
    The new nut will be a nyloc with Loctite.
    in reply to: 170 miles to go #10852
    I didn’t have much time today. I did remove the nut from the pulley. Even without the nut the camshaft splines should engage with the pulley. The pulley is not connected to the splines.
    I shall pull off more stuff tomorrow and report.
    in reply to: Building up thin metal #10842
    in reply to: Maybe not quite two years to go #10839
    For the handbrake, no.
    For lights left on, yes!
    in reply to: Maybe not quite two years to go #10831
    in reply to: Maybe not quite two years to go #10830
    Here’s the wheel
    in reply to: Maybe not quite two years to go #10824
    Wrapped steering wheels.
    It has taken five attempts and eight feet of shrinkwrap to get it right to learn a technique.
    What I’ve learnt.
    You will also need asbestos fingers!
    Once the wrap is threaded on to the stem, push it as far up to the wheel as possible. Gently heat the last inch until it shrinks a bit. Poke, push or cajole the wrap under the chrome finisher. Once it’s in a about quarter inch, heat just that area until it fully shrinks.
    Then remove the loom tape. Ta Daa.
    Being an idiot, I then shrunk on another layer. It went OK.
    in reply to: Building up thin metal #10810
    Once painted it looked OK.
    How much of that part is visible? Should it be paint or chrome?
