I just wrote a long reply, tried to post and the poxy forum said members only.
Logged back in, post gone.
Can’t be bothered…..Filler is like HP and tomato sauce, the profit is what’s left on the plate.
More DA action tomorrow.
Once I’ve hung the doors and wings I can use filler to get it right (ish).If my doors had been good but just dented, I’m sure I could have corrected the dents.
And buy another big tub of filler!A foregone conclusion, myself and panel beating don’t get on.
Hooray for filler! Lots of it.Here are a few things I can recommend if revitalising your loom. All from Vehicle Wiring Products.
Peter
Peter here again.
Have you an alternator with an external regulator in a box on the side of the battery or an internal regulator?There is something about BVH and the ignition warning light if you opt for internal regulation.
Citroen did odd things with the wiring. The cable from the battery has two other wires spliced to it within the loom tape. Maybe they changed something and opted for three separate cables.
Paul will chime in soon with his experience. Paul also has a BVH. Mine are both BVM.
Calling Paul.
I’m sure Paul bought a new loom from the man who makes them.
The looms are a minefield with umpteen variations.
I make my own, not too difficult if you are methodical.
Do you mean a new ignition key or ignition switch? Three dial dash or earlier?The last time I polished something on my bench grinder when I took off my goggles I looked like Stirling Moss after a race.
Regarding the bolt on part that hooks the bonnet. How about bolting it on as is then using a crescent wrench to bend and twist it to the correct position?
I’m good at brute and ignorance.A DS is a baptism of fire!
I broke myself in gently with a Triumph Bonneville, then the mechanics of a Frogeye Sprite, then a Marcos Coupé.
My first full on restoration was the four seater Marcos Mantis. A hateful car that would break down in the garage. I sold that to Jem Marsh (Mar of Marcos). They crashed it into a wall because the clutch had rusted together.
The biggest mistake I made was starting off with half inch drive sockets. Now I use 1/4″ almost exclusively.On the first two doors I repaired, they needed at least 6mm of filler at the join to restore the contour. The third door will need about 3mm of filler.
My overall attitude has also changed due the conflict of ambition over ability.
The thrust of my restoration is now for good mechanics and a non rusting body.
The Safari will fall into the category of good for an amateur, poor for a professional restoration.
After seven motorbike and eight car restorations I’ve almost had enough. The next restoration will be my 1940s milling machine.Two doors too late I’ve realised the outer skin repair panels are folded too much at the swage line.
I had tacked the third skin on when I saw the problem. I cut off the tacks. With the skin on the bench, and the folded ends straightened, I squashed the panel flat with my hands.
It didn’t go completely flat, there was still quite a swage line. When slid back into place, there was no longer a dip at the join.
With a plug weld every inch, it is definitely on.Next was removing the multiple dents. You really have to thump the skin to push out the dents. Tippy tapping just does not work.
The dents are now down to small bumps and hollows. More crash, bang, wallop tomorrow. Then the DA with 80 grit and epoxy primer.
And filler.About 40 years ago I bought a pack of 1 metre long silicon bronze brazing wires for £25. I have hardly used any, except as a “fish” to pull wires through pipes etc. I recently discovered they are worth a fortune!
Now I just use general purpose fluxed brazing rods 3.2mm. I still use extra flux, SIF bronze. If you can get it, you can use borax.
I do have oxy-acetylene. The general purpose rods can be used with MAPP gas, but blowlamps tend to heat up large areas.
