Viewing 15 posts - 1 through 15 (of 805 total)
  • in reply to: Hello from Wiltshire #13910
    in reply to: Hello from Wiltshire #13909
    I changed it to free
    Woolies don’t list them.
    They nearly always break when you try to remove them, so don’t!
    in reply to: Hello from Wiltshire #13908
    Dash dial.
    Plus the speedo’s are carp.
    I think it is black.
    One wire goes to earth.
    Take the relay out.
    Terminal 86 goes to earth
    Terminal 30 is live feed
    Terminal 87 goes to headlamp.
    Fresh oil sounds OK.
    Or.
    Similarly at the fan.
    It is heavy.
