I didn’t need it when I had a puncture in Loire, just a new ‘chambre d’air’.When I had a Marcos, the steering column went through the fan belt. The trick was to fit two. One on the pulleys, one tied up out of the way.
Maybe cable-tie a spare to the new one. Similar to a spare clutch cable in the non Pallas roof channel.I have a brace. DSuper5, from Olivier. I have rebuilt the engine etc.
I bought mine 10 years ago. Did nothing for 18 months and then a year off when I was ill. Otherwise a few hours a day, every day.Bodywork is the most tedious, long winded, pain in the backside.
Can you spray a car? If you can’t, sit down before you get the quote.I would buy the best DSuper5 you can find.
Then drive it. No need to mollycoddle it.I asked Jamie. No need to remove the engine. Maybe give him a call. After 11am is best.
If you want the starter motor to be ignition switch controlled, then delete the wire from terminal 85. Instead take a wire from pin 2 of the ignition switch to 85.
That way, the starter motor can only operate if the ignition is switched on.If you haven’t got a Daisy wheel on the positive battery post, this is how I would do it.
I use a 70amp relay because terminals 30 and 87 are larger and can accommodate larger wire. It is overkill.
Using a relay reduces the amount of current going through the piddly switch on the gear lever. It stops the contacts burning out.I crimp and solder the connections using leaded solder. Never had a problem in 40 years.
I know mine are BVM. I fit a 40amp
relay between the starter switch and the solenoid on the starter.
If you have 8 wires, disregard pins 7 and 8.On the 40amp relay, battery goes to 30, 87 goes to starter solenoid.
Assuming the microswitch on the gear wand earths to complete the circuit, 85 can also come from the battery, 86 goes to microswitch. When the wand is moved to start, it earths 86 which then closes the relay and the solenoid gets power.
The new ignition switches are carp, avoid.
Der Franzose shows all the types of spheres and pressures, in bars. 1 bar = 15lbs.
