That was not a job I wish to repeat too soon. 12 hours over four days.
I did take the opportunity to change the radiator fan switch to one which switches on at a higher temperature. I also added a drain tap to the aluminium radiator.Once you’ve accepted what work has to be done to achieve the required outcome, you just have to get on with it. There was nothing tricky, just long winded.
I finished with one m9 nut extra because I found it stuck to the undertray. Plus a load of m4 and m5 nuts and washers. Only an optimist would drop one nut or washer and get one new one from the spares case. I always lose one, bring back five to replace it.It may have been the loss of the spring washer I had used. These days spring washers are carp. Another factor may be the air-con compressor adding an extra jolt.
The end of the camshaft was the same diameter along the threaded length. The nylon part definitely comes into play.I shall put the dead pulley in the lathe and cut off the rivet heads to see how it comes apart.
Most of the gubbins are back in place. I need to machine a couple of M9 nuts as the originals fell into the black hole, never to be seen again.When I rebuilt this engine I used a split locking washer under the pulley nut. I can see it had fallen apart and disappeared allowing the pulley to wobble.
The new nut will be a nyloc with Loctite.I didn’t have much time today. I did remove the nut from the pulley. Even without the nut the camshaft splines should engage with the pulley. The pulley is not connected to the splines.
I shall pull off more stuff tomorrow and report.Hello, if you copy and paste bb fully linked the picture will appear in the thread.
For the handbrake, no.
For lights left on, yes!Did the eagle eyed notice a parking brake warning light marked P in white?
Here’s the wheel
Wrapped steering wheels.
Start the engine, needle drops back to bottom then slowly rises with engine temperature.My saloon uses a converted fuel gauge. Needle only moves with rising engine temperature.
Replacing curvy rusted steel is not my forte. Luckily, filler is.Looking in my crystal ball I can forsee many trips to AFT Fluorotec in Welwyn Garden City. Burning off the paint and filler in their oven. Home to repair. Back again to hot zinc spray the seams. Back home for epoxy primer.
But can only do one panel at a time to stop flash rusting.The top coats will be cellulose. Pretty user friendly and doesn’t need a separate air supply to the hood.
