Viewing 15 posts - 1 through 15 (of 763 total)
  • in reply to: Sh*t Just Got Real….. #12949
    Like this
    in reply to: EFI throttle linkage – reconnection #12759
    I asked Jamie. No need to remove the engine. Maybe give him a call. After 11am is best.
    in reply to: Workshop Manuals and Parts Books #12758
    in reply to: Manual to bvh #12750
    Imgbb is messing around and I can’t find how to delete posts.
    Last try.
    in reply to: Manual to bvh #12749
    Imgbb are messing about.
    in reply to: Manual to bvh #12748
    in reply to: Manual to bvh #12747
    If you want the starter motor to be ignition switch controlled, then delete the wire from terminal 85. Instead take a wire from pin 2 of the ignition switch to 85.
    That way, the starter motor can only operate if the ignition is switched on.
    in reply to: Manual to bvh #12746
    If you haven’t got a Daisy wheel on the positive battery post, this is how I would do it.
    I use a 70amp relay because terminals 30 and 87 are larger and can accommodate larger wire. It is overkill.
    Using a relay reduces the amount of current going through the piddly switch on the gear lever. It stops the contacts burning out.
    I crimp and solder the connections using leaded solder. Never had a problem in 40 years.
    in reply to: Manual to bvh #12743
    I know mine are BVM. I fit a 40amp
    relay between the starter switch and the solenoid on the starter.
    If you have 8 wires, disregard pins 7 and 8.
    On the 40amp relay, battery goes to 30, 87 goes to starter solenoid.
    Assuming the microswitch on the gear wand earths to complete the circuit, 85 can also come from the battery, 86 goes to microswitch. When the wand is moved to start, it earths 86 which then closes the relay and the solenoid gets power.
    The new ignition switches are carp, avoid.
