I fitted a 20psi modern sender from Demon Tweaks and used the necessary adaptor to make it fit.
Definitely spray some Dinitrol, Bilt Hamber or your favourite into the doors. While you’re at it, paint some onto the door bottoms.I changed it to free
Dash dial.
I think it is black.
One wire goes to earth.
Terminal 86 goes to earth
Terminal 30 is live feed
Fresh oil sounds OK.
