NPT is tapered. I’d rather trust PTFE tape over a copper washer.
https://www.ebay.co.uk/itm/363619541090
1/8″ NPT Female To M10x1.5 Male Stainless Steel Reducer Gauge Take Off Adapter
The adaptor is M10 male, screws into the block with a bit of PTFE tape. Switch, 18NPT, screws into adaptor with a bit more PTFE tape.
I did the switch into the adaptor first, adaptor in vice, tightened switch with water pump pliers. Then whole lot into block.https://www.ebay.co.uk/itm/301122237169
plus
https://www.ebay.co.uk/itm/37256485455020psi switch plus adaptor.
Original switches operate at about 3psi, far too late.I fitted a 20psi modern sender from Demon Tweaks and used the necessary adaptor to make it fit.
Definitely spray some Dinitrol, Bilt Hamber or your favourite into the doors. While you’re at it, paint some onto the door bottoms.I changed it to free
Dash dial.
I think it is black.
I’ve made a new drawer for the middle of the dash. It has a tree wood facia, posh! -
