One wire goes to earth.
Terminal 86 goes to earth
Terminal 30 is live feed
Fresh oil sounds OK.
Similarly at the fan.
It is heavy.
Crusty shaft repair.
Speedi Sleeves by SKF
Der Franzose part numbers
30384
And30270
Have fun.
