I didn’t need it when I had a puncture in Loire, just a new ‘chambre d’air’.When I had a Marcos, the steering column went through the fan belt. The trick was to fit two. One on the pulleys, one tied up out of the way.
Maybe cable-tie a spare to the new one. Similar to a spare clutch cable in the non Pallas roof channel.I have a brace. DSuper5, from Olivier. I have rebuilt the engine etc.
I bought mine 10 years ago. Did nothing for 18 months and then a year off when I was ill. Otherwise a few hours a day, every day.Bodywork is the most tedious, long winded, pain in the backside.
Can you spray a car? If you can’t, sit down before you get the quote.I would buy the best DSuper5 you can find.
Then drive it. No need to mollycoddle it.I asked Jamie. No need to remove the engine. Maybe give him a call. After 11am is best.
If you want the starter motor to be ignition switch controlled, then delete the wire from terminal 85. Instead take a wire from pin 2 of the ignition switch to 85.
That way, the starter motor can only operate if the ignition is switched on. -
