Definitely spray some Dinitrol, Bilt Hamber or your favourite into the doors. While you’re at it, paint some onto the door bottoms.I changed it to free
Dash dial.
I think it is black.
One wire goes to earth.
Terminal 86 goes to earth
Terminal 30 is live feed
Fresh oil sounds OK.
Similarly at the fan.
It is heavy.
