Looks a good neat job.
I always have grand plans of things to do in the garage over winter and then remember how cold it is!
The 28 and 26 mechanism is neat. I’d argue that 27 isn’t essential as I managed it on the first door I did but I’m not sure that argument would stand up as the process was deeply unpleasant! In the end I had to use a woodworking clamp on the handle backing plate that would compress the foam in the trimming enough for parts 26 and 28 to engage while having a hand wedged up inside the door holding part 26 in place. Really wish I’d done the other door first so I would have known about 27 🙁
I’ll have a rummage through my assorted washers box and see if anything can be adapted if I’m missing any more. I’m also considering just 3D printing a little washer that could hold 26 in place if necessary.
Thanks for the other tips on the doors, I’d missed that 32 and 33 were there to carry the rods, I’ll check that they’re in place.
I’m doing one door at a time. If there’s a better knack of getting the top trim that holds the pleated leathery bit off Pallas doors then I’m yet to find it. Plastic trim tools to lever the shiny bit up then get a screwdriver in to undo the self tappers is kind of working but doesn’t feel optimal, I guess they were ever designed to come off really.
Now on my second door I’ve found a component I didn’t have on the first one
Part 27 on the diagram is incredibly useful to hold the threaded piece in place while you position the handle. On the first one I had an utter nightmare trying to hold the back of the screw in the door while lining the handle part up, walked away a few times in frustration, never thought that I was missing a part!
That’s a nice touch, I like that, tempted to do the same!
It is really good to be driving again, sadly they’ve been gritting the roads around here so I need to think carefully about whether I want it to have a salty bath just yet!
I’m being very cautious with the bits and bobs I’m doing on the car as I want to be able to drive it as and when opportunity arises. They’ll be time in the depths of winter to attack more jobs…
It came with an engine
One knackered door card
Thanks again
Chris
Thanks Paul, much appreciated
Welcome to your new home!
