Chris Reynolds
Viewing 15 posts - 1 through 15 (of 35 total)
  • in reply to: Hello from Wiltshire #13968
    I’m doing one door at a time. If there’s a better knack of getting the top trim that holds the pleated leathery bit off Pallas doors then I’m yet to find it. Plastic trim tools to lever the shiny bit up then get a screwdriver in to undo the self tappers is kind of working but doesn’t feel optimal, I guess they were ever designed to come off really.
    Now on my second door I’ve found a component I didn’t have on the first one
    Part 27 on the diagram is incredibly useful to hold the threaded piece in place while you position the handle. On the first one I had an utter nightmare trying to hold the back of the screw in the door while lining the handle part up, walked away a few times in frustration, never thought that I was missing a part!
    in reply to: Hello from Wiltshire #13965
    That’s a nice touch, I like that, tempted to do the same!
    It is really good to be driving again, sadly they’ve been gritting the roads around here so I need to think carefully about whether I want it to have a salty bath just yet!
    I’m being very cautious with the bits and bobs I’m doing on the car as I want to be able to drive it as and when opportunity arises. They’ll be time in the depths of winter to attack more jobs…
    in reply to: Hello from Wiltshire #13963
    It came with an engine
    One knackered door card
    in reply to: Nearly There! #13938
    in reply to: Carpet fitting #13924
    Thanks again
    Chris
    in reply to: Hello from Wiltshire #13914
    in reply to: Hello from Wiltshire #13907
    Thanks Paul, much appreciated
    in reply to: Hello from Wiltshire #13904
    in reply to: Hello from Wiltshire #13884
    in reply to: Hello from Wiltshire #13882
    in reply to: Hello from Wiltshire #13879
    Welcome to your new home!
    in reply to: Three dial dash #13869
    in reply to: Nearly There! #13362
    in reply to: Nearly There! #13360
    in reply to: New member with lots of questions! #13224
