David McPhee
Viewing 15 posts - 1 through 15 (of 18 total)
  • in reply to: Sticky starter motor #10917
    Hi Paul, thanks yet again for a very comprehensive reply. I’ll go out now and look for the relay you mention.
    It’s a DSpecial from September 1972. But in the early 90’s was upgraded with a 5 speed 2175
    Dave
    in reply to: Rear Screen Heater #10658
    Thanks for all the ideas, in the end I took the circuit for the screen heater and wired in a cigarette lighter socket. I have a small electric fan heater that just plugs in sat on the parcel shelf. Don’t even need to switch it on and off because I can just use the switch on the dashboard.
    Boot light has gone off again! I’ve got 12v across the bulb holder terminals but the bulb just won’t light. I’ve tested the bulb and it’s a good one.
    in reply to: Driving lamp vertical adjustment #10249
    Driving not during
    in reply to: Driving lamp vertical adjustment #10248
    Amazing, so there is! I’ll have a go at that letter when it’s dark. Thank you so much, sorry for so many simple questions. Loving during my D, learning so much all the time. Dave
    in reply to: No instrument lights #10141
    I did yes, bit embarrassed I didn’t realise in the first place, it’s obvious when you know. But also the bullet connector to the rheostat had come off! So thanks for prompting me to look there too. Lovely and bright now.
    in reply to: No instrument lights #10123
    Thanks Peter and Paul, I’ve been on a little road trip to London, 300 miles and it didn’t miss a beat. So only just had time to get the facia off for a proper look. Blown bulb! Dave
    in reply to: Fuel type #10019
    Thanks everyone as always very helpful. For whatever reason my D has been fitted with a modern electric fuel pump so ought to be OK. I’ll check that rubber connector Paul mentioned and try replacing it with modern fuel pipe. I’d forgotten that not all E10 contains 10% ethanol. I’ll bear in mind and keep an eye on the fuel inlet connector that John mentioned.Thanks again. Dave
    in reply to: Anyone know what this is? #9760
    Thanks Peter, I’ll have another look. Was tying to compare both sides but couldn’t see any difference, I know where to look now. I wasn’t doing anything drastic, just adjusting the lights and replacing a faulty bulb.
    in reply to: Anyone know what this is? #9757
    A picture of my recent purchase…
    in reply to: Anyone know what this is? #9756
    in reply to: Anyone know what this is? #9754
    91-D8-A3-FE-DA6-F-4-C28-AA12-08556-A9-DA646
    in reply to: Anyone know what this is? #9753
    Sorry everyone, struggling to attach the photo.
    in reply to: Floppy front headlight #9735
    Ahh that makes sense, they are missing!
    in reply to: Floppy front headlight #9733
    Thanks to all for your help so far but it’s not that adjuster block that’s missing, they are both there and in good condition. It’s the very end where it attaches to the headlight reflector that seems to be the problem. There’s a “bracket” on the back of the reflector but it’s like there’s something missing that the end of the rod should clip into? I can’t see far enough into the near side to compare.
    in reply to: Floppy front headlight #9728
    Great, thank you, I’ll get a couple ordered in case the other side breaks too.
