Ian Anderson
Viewing 15 posts - 1 through 15 (of 65 total)
  • in reply to: Hello from Wiltshire #13040
    Lots of good advice here. I agree that a D Super 5 seems to be regarded as the ‘sweet spot’, or an earlier D Super with the optional 5 speed box.
    In regards to ‘Pallasisation’ I thought it was only Pallas spec cars that had the large aluminium heat shield on the engine side of the firewall? If so, that would be major ‘tell’ as it would be an engine out job to fit I think.
    Incidentally, my 1970 D Super (Dec 69 build) has the DY 2 / 17N engine as per above. Built before the 5 speed became an optional extra, which was mid 1970 year I think, and as said it was a close ratio ‘mountain’ gearbox. It’s specced almost identically to the DS 20 BVM, bar the extra brake accumulator, vinyl seats (cloth was an option), turning but not self levelling lights (this was an option) and the inner lamps are high beam not driving lights (again I think this was an option), and gold chevrons on the boot of course. Perhaps because it was an export model (originally an NZ car).
    in reply to: Sh*t Just Got Real….. #13039
    My heart bleeds for you all. Power tools? Welders? Compressors? My garage is the street. So in theory all the space to manoeuvre about you could want. In reality… well you can imagine.
    in reply to: Chassis Colour #10944
    Thanks Paul, very informative. Leaving them unpainted seems to be asking for trouble. I know Citroen had a none exitant approach to body protection, but even by their standards this seems cavalier!
    in reply to: Chassis Colour #10940
    Thanks Peter, mine are going to sitting in a bath of Deox-C, then epoxy, primer and coach enamel. Haven’t decided what to spray over it afterwards.
    in reply to: What’s this attached to my battery frame? #10933
    Looks like the voltage regulator. If you’ve got an upgraded alternator which has internal regulation, you might not need it, but I’m not up on my electrickery.
    in reply to: Rear Screen Heater #10689
    Thanks Paul and Peter, I’m not too fussed about the boot light right now, useless anyway. That whole rear light loom is dodgy as my interior lights have come on all of twice when I open the doors. Suspect the problem is behind the dash though, so I’m ignoring it!
    in reply to: Throttle Linkage Plate #10682
    Hi. It’s pretty much as Peter said. The full Citroen instructions are at operation D-142-0 in volume 1 of manual 814. it’s fairly near the front of the book – just before the pages on carburettors.
    it’s just one page – but helpful.
    Thanks Paul, my D-142-0 in 814 doesn’t have that, just on how to measure and adjust the springs on the throttle control rod.
    in reply to: Throttle Linkage Plate #10680
    in reply to: Rear Screen Heater #10679
    in reply to: Two years to go, possibly #10678
    All done in the end.
    I feel your pain. Flexi into the main silencer was incredibly tight. I used Mikalor clamps but the they weren’t strong enough to clamp stainless, started to bend and one of the bolts actually snapped. Tried a different brand of clamps, same result, so back to ugly U clamps. I now know why the previous owner welded up the joints on the old exhaust…
    in reply to: Two years to go, possibly #10672
    in reply to: Rear Screen Heater #10671
    in reply to: Two years to go, possibly #10584
    in reply to: Two years to go, possibly #9949
    in reply to: Gris Rose v Gris #9948
    Hi all,
