The retail operation of ATS has closed. Anyone know of alternatives in NW England, or anywhere if I get desperate?
Thanks very much Paul. I will contact Philip.
Rather than create a new thread on travelling to France, I thought I would jump on this one. I am thinking of going to Paris next week in a D Super 1971. Low emission zones crossed my mind. Even if historic vehicles must comply surely any D is exempt, even if only informally?
Steve
After a long drab, winter with no work on the car I am now getting my wheels sandblasted and repainted.
1 Removing the wheels – Does anyone have a picture of the jacking points? I have never put the car on axle stands before. Do you loosen wheel nuts, raise to the high position and put stands under the appropriate places at all four corners? I will need to leave the car like this for a couple of weeks.
2 Paint – I am going for AC140 – but the painter has asked me for a RAL code. Peter Bremner used RAL7044. Is this the same? Also, the painter is going to use Enamel paint. Is this OK?
