Thanks very much Paul.
Steve
Thanks Paul. It is very difficult to compare on a computer. The colours can look completely different in real life. I looked at a real swatch in the paint shop today and RAL7044 did look quite close to a grey (I believe gris roue) wheel that I picked up off eBay last year. By the way that rust effect that you have cultivated looks interesting, it might look good on the Decrap of Richard Edwards!
After a long drab, winter with no work on the car I am now getting my wheels sandblasted and repainted.
1 Removing the wheels – Does anyone have a picture of the jacking points? I have never put the car on axle stands before. Do you loosen wheel nuts, raise to the high position and put stands under the appropriate places at all four corners? I will need to leave the car like this for a couple of weeks.
2 Paint – I am going for AC140 – but the painter has asked me for a RAL code. Peter Bremner used RAL7044. Is this the same? Also, the painter is going to use Enamel paint. Is this OK?
I bought one of these. https://www.coveryourcar.co.uk/store/product.php?productid=16724&cat=641&page=1
Thanks all for your comments. I might be tempted to go back to the original Grey AC140. It looks good to me and is the original colour.
I have just seen this Wheel Colours. Is this telling me that all IDs/DSupers were Gris Rosé?
