Chris Pryer
Viewing 10 posts - 1 through 10 (of 10 total)
  • in reply to: Lower ball joint #8164
    Hi Alan, I expect you have sorted your bottom ball joint search problem. Just to let you know though that someone has posted a NOS early spec joint (up to 1974) for sale on Facebook ‘Citroen CX Parts for sale/wanted’
    in reply to: Front suspension #7726
    Hi Stan, do you mean the rubber dust guards for the suspension cylinders? if so both CX Basis of Germany and Chevronics in the UK do them.
    in reply to: CX front door glass #7352
    Hello Paul, I’m not sure myself but Stan Platts will know for sure, give him a ring.
    in reply to: Series 1 Dashboard #6927
    Hi Ted, you could try Stan Platts in the UK, he knows all there is to know about the CX and has a large amount of CX spares. Don’t know an email for him only phone number. 01274 683848. Worth a try, good luck.
    in reply to: windscreen washer piping on wiper arm #6913
    Hi Stan, if not an Ebay seller then what about contacting Stan Platts, I’m sure he will have a good used item.
    in reply to: CX Handbook #6898
    Hi Stan,
    Try posting a wanted add on Facebook, ‘Citroen CX-parts for sale/wanted’ or the ‘Citroen CX unofficial fan club’
    sites for a handbook or help and info.
    in reply to: CX 25 water pump #6493
    Could be extra charges on top if coming from EU these days. Also I believe there is more than one type, different CX models etc.
    in reply to: CX Paint codes #6400
    Not 100% sure but on my 1988 Series2 DTR the paint code is stenciled in white paint on the o/s suspension turret.
    in reply to: CX Turbo s1 – What are these wires? #6231
    I would say that the top wire is for the ABS sensor feed and the lower ones are for the low brake pad warning. If odometer/ speedo not working likely to be a cable.
    in reply to: CX Headlights #6230
    No you can not adjust for UK roads, only adjustment is for left/right, up and down. You could put tape in the right places to knock out the kick up but best thing to do long term is to remove the glasses and replace with UK right hand drive spec, easy to do and I’m sure if you ask around plenty of replacements available. Try Citroen CX parts for sale and wanted, or Citroen CX unofficial fan club.
