Simon Lewthwaite
Viewing 15 posts - 1 through 15 (of 145 total)
  • in reply to: First Long Trip! #13234
    Will do and thanks all.
    Looking lovely Paul
    in reply to: Crusty #12182
    Is that bit of wood straight?
    It looks amazing Paul.
    Gris Nacre?
    in reply to: Paint colour DS 23 1972 WHEEL RIMS #12094
    in reply to: Waxoyl etc #11874
    Thanks everyone.
    I’ll get on it
    in reply to: Waxoyl etc #11851
    Thankyou both
    Cripes, lots to do!
    I do have a compressor so will look to getting the Sealey kit
    in reply to: Temperature Sensor for fuel injection #11675
    in reply to: Temperature Sensor for fuel injection #11661
    Thanks Paul,
    Really useful going forwards.
    in reply to: Temperature Sensor for fuel injection #11607
    Here is how I got on.
    These thermistors cost around 30p each. Got 10. I decided to attempt a compete OEM look, otherwise, little point. In the end, I could always have just used wires to connector.
    Heat shrink
    Soldered onto original connectors
    Epoxied into housing using the female connector as a ‘guide’
    Then filled the sensor body with thermal paste (most tricky bit – a long needle to back fill would have been useful. Then all expoxied back together
