Will do and thanks all.
Is that bit of wood straight?
Thanks everyone.
I’ll get on itThankyou both
Cripes, lots to do!I do have a compressor so will look to getting the Sealey kit
Thanks Paul,
Really useful going forwards.Here is how I got on.
These thermistors cost around 30p each. Got 10. I decided to attempt a compete OEM look, otherwise, little point. In the end, I could always have just used wires to connector.
Heat shrink
Soldered onto original connectors
Epoxied into housing using the female connector as a ‘guide’
Then filled the sensor body with thermal paste (most tricky bit – a long needle to back fill would have been useful. Then all expoxied back together
