Is that bit of wood straight?
Thanks everyone.
I’ll get on itThankyou both
Cripes, lots to do!I do have a compressor so will look to getting the Sealey kit
Thanks Paul,
Really useful going forwards.Here is how I got on.
These thermistors cost around 30p each. Got 10. I decided to attempt a compete OEM look, otherwise, little point. In the end, I could always have just used wires to connector.
Heat shrink
Soldered onto original connectors
Epoxied into housing using the female connector as a ‘guide’
Then filled the sensor body with thermal paste (most tricky bit – a long needle to back fill would have been useful. Then all expoxied back together
Re carpet edge binding.
Hard to explain.
I would definitely get a walking foot attachment to prevent the carpet ‘curling’With the carpet face up, Lay the binding away from the edge and stitch it to the front, along the line where you want it to reach.
Now, fold the binding over on itself, around the edge and stitch it again, just beyond the first line. In this way, no stitching at all will be seen, given its black thread on black carpet. Its easier if you do this step with the carpet turned over so you can keep the binding taught and neat. I did initially run some contact adhesive to help this step but quickly got the knack and stopped using it.
There are some very nice videos online of a guy stitching carpet in a variety of ways, tips and tricks. Cechaflo I thinkJust running through topics I had started.
I have the answer to this one – I have no reversing lights! (face-palm)
There are holes in the rear cross member thing which no doubt once had them, there are the wires from the gearbox in the engine bay and I recall some strange cut off wires behind the rear seat back rest that went no where.Mystery solved.
I’m in no rush to refit at the moment as the originals look rather bulky but perhaps a semi-hidden modern light would be wise in the long run.I had kind of assumed the reversing light(s) were in the main light cluster but when I tried to refurbish those, it was clearly not the case. I say ‘tried’ because I completely failed to re-chrome the plastic. Just ended up with a gloss grey in the end.
