Simon Lewthwaite
Viewing 15 posts - 1 through 15 (of 143 total)
  • in reply to: Light pods in wings ? #12223
    Looking lovely Paul
    in reply to: Crusty #12182
    Is that bit of wood straight?
    It looks amazing Paul.
    Gris Nacre?
    in reply to: Paint colour DS 23 1972 WHEEL RIMS #12094
    in reply to: Waxoyl etc #11874
    Thanks everyone.
    I’ll get on it
    in reply to: Waxoyl etc #11851
    Thankyou both
    Cripes, lots to do!
    I do have a compressor so will look to getting the Sealey kit
    in reply to: Temperature Sensor for fuel injection #11675
    in reply to: Temperature Sensor for fuel injection #11661
    Thanks Paul,
    Really useful going forwards.
    in reply to: Temperature Sensor for fuel injection #11607
    Here is how I got on.
    These thermistors cost around 30p each. Got 10. I decided to attempt a compete OEM look, otherwise, little point. In the end, I could always have just used wires to connector.
    Heat shrink
    Soldered onto original connectors
    Epoxied into housing using the female connector as a ‘guide’
    Then filled the sensor body with thermal paste (most tricky bit – a long needle to back fill would have been useful. Then all expoxied back together
    in reply to: interiors n’stuff #11604
    Re carpet edge binding.
    Hard to explain.
    I would definitely get a walking foot attachment to prevent the carpet ‘curling’
    With the carpet face up, Lay the binding away from the edge and stitch it to the front, along the line where you want it to reach.
    Now, fold the binding over on itself, around the edge and stitch it again, just beyond the first line. In this way, no stitching at all will be seen, given its black thread on black carpet. Its easier if you do this step with the carpet turned over so you can keep the binding taught and neat. I did initially run some contact adhesive to help this step but quickly got the knack and stopped using it.
    There are some very nice videos online of a guy stitching carpet in a variety of ways, tips and tricks. Cechaflo I think
    in reply to: Reversing light cable #11598
    Just running through topics I had started.
    I have the answer to this one – I have no reversing lights! (face-palm)
    There are holes in the rear cross member thing which no doubt once had them, there are the wires from the gearbox in the engine bay and I recall some strange cut off wires behind the rear seat back rest that went no where.
    Mystery solved.
    I’m in no rush to refit at the moment as the originals look rather bulky but perhaps a semi-hidden modern light would be wise in the long run.
    I had kind of assumed the reversing light(s) were in the main light cluster but when I tried to refurbish those, it was clearly not the case. I say ‘tried’ because I completely failed to re-chrome the plastic. Just ended up with a gloss grey in the end.
