Simon Lewthwaite
Viewing 15 posts - 1 through 15 (of 147 total)
  • in reply to: Damaged Hydraulic pipe from pump to regulator #13272
    Will do and thanks all.
    Looking lovely Paul
    in reply to: Crusty #12182
    Is that bit of wood straight?
    It looks amazing Paul.
    Gris Nacre?
    in reply to: Paint colour DS 23 1972 WHEEL RIMS #12094
    in reply to: Waxoyl etc #11874
    Thanks everyone.
    I’ll get on it
    in reply to: Waxoyl etc #11851
    Thankyou both
    Cripes, lots to do!
    I do have a compressor so will look to getting the Sealey kit
    in reply to: Temperature Sensor for fuel injection #11675
