So the flaring tool itself costs around £250 but you have to buy specific sized die set for the given pipe. each around £30-40.
Just thinking ahead to rerouting possibilities.Yes, my air filter is exactly like that – essentially sucking the air from the trumpet horns!!
Unfortunately, Andy’s site doesn’t seem to be working. I think there would be space using those existing holes.Thanks for all the advice.
Oh, and I did change the sphere – think this must have been failing anyway as now, the main pump seems to come on far less.I have ordered the pipe. Once it arrives, I will cut a length of standard brake pipe to same length and practice the route.
Have ordered sphere too.
Will update….I have heard back from Darrin. He strongly advises changing the whole pipe as cupronickel is inappropriate for this application. Needs to be steel or stainless.
Will do and thanks all.
Is that bit of wood straight?
I have used this to repolish some of my DS parts and although it certainly works, its a lengthy process and I would expect to pay £££ for someone else to do it. -
