Simon Lewthwaite
Viewing 15 posts - 1 through 15 (of 152 total)
  • in reply to: Damaged Hydraulic pipe from pump to regulator #13332
    So the flaring tool itself costs around £250 but you have to buy specific sized die set for the given pipe. each around £30-40.
    Just thinking ahead to rerouting possibilities.
    in reply to: Damaged Hydraulic pipe from pump to regulator #13304
    Yes, my air filter is exactly like that – essentially sucking the air from the trumpet horns!!
    Unfortunately, Andy’s site doesn’t seem to be working. I think there would be space using those existing holes.
    in reply to: Damaged Hydraulic pipe from pump to regulator #13290
    Thanks for all the advice.
    Oh, and I did change the sphere – think this must have been failing anyway as now, the main pump seems to come on far less.
    in reply to: Damaged Hydraulic pipe from pump to regulator #13284
    Have ordered sphere too.
    Will update….
    in reply to: Damaged Hydraulic pipe from pump to regulator #13275
    Will do and thanks all.
    Looking lovely Paul
    in reply to: Crusty #12182
    Is that bit of wood straight?
