Simon Lewthwaite
Viewing 15 posts - 1 through 15 (of 150 total)
  • in reply to: Damaged Hydraulic pipe from pump to regulator #13290
    Thanks for all the advice.
    Oh, and I did change the sphere – think this must have been failing anyway as now, the main pump seems to come on far less.
    in reply to: Damaged Hydraulic pipe from pump to regulator #13284
    Have ordered sphere too.
    Will update….
    in reply to: Damaged Hydraulic pipe from pump to regulator #13275
    Will do and thanks all.
    Looking lovely Paul
    in reply to: Crusty #12182
    Is that bit of wood straight?
    It looks amazing Paul.
    Gris Nacre?
    in reply to: Paint colour DS 23 1972 WHEEL RIMS #12094
