Thanks for all the advice.
Oh, and I did change the sphere – think this must have been failing anyway as now, the main pump seems to come on far less.I have ordered the pipe. Once it arrives, I will cut a length of standard brake pipe to same length and practice the route.
Have ordered sphere too.
Will update….I have heard back from Darrin. He strongly advises changing the whole pipe as cupronickel is inappropriate for this application. Needs to be steel or stainless.
Will do and thanks all.
Is that bit of wood straight?
